1995 Mercury Sable engine won't start
SPARKLE612
Engine Performance problem
1995 Mercury Sable 6 cyl Wheel Drive Type unknown Automatic 159,00 miles
I replace alternator, battery, and rotor under distributor cap car cranks but won't start
Mar 14, 2008 at 1:15 PM
JHALL1973
You need to check to see if you get a spark from you plugs. There is a cheap spark plug tester you can get.
If you have a spark listen for the fuel pump to come on whe you turn the key. YOU should here it purge up for a second. if not start with the relay then test to see where the volts die in the circuit. if there is power to the fuel pump the it may be dead or a sensor my trigger it to stay off.
Apr 15, 2008 at 3:47 AM
