1995 Mercury Sable
SBUNNIS
  • 1995 MERCURY SABLE
Transmission problem
1995 Mercury Sable 6 cyl Front Wheel Drive Automatic
My upper trany. Line is leaking fluid at the coupler I replaced both upper and lower couplers but the line still leaks BAD what can I do
Tuesday, December 15th, 2009 AT 6:45 PM
BMRFIXIT
  • 19,053 POSTS
At the tranny side or by the radiator
if at the radiator you can bypass it and use an after market small tranny cooler
Tuesday, December 15th, 2009 AT 7:22 PM
SBUNNIS
It leaks right at the coupler on the transmission
Tuesday, December 15th, 2009 AT 7:49 PM
BMRFIXIT
  • 19,053 POSTS
Did you try using teflon
Tuesday, December 15th, 2009 AT 8:04 PM
SBUNNIS
It not leaking were it screws into the tranny its leaking(pouring) ouy where the line goes into the quick coupler and everything is all new. Im thinking about putting in a compression fitting and elimanating the coupler. Go with the old screw in type
Tuesday, December 15th, 2009 AT 8:32 PM
BMRFIXIT
  • 19,053 POSTS
Yes I see know what you mean
them are pain and if not all the way in and secure it will look like as it is in
you can change the set up as you like
I always did
good luck
Tuesday, December 15th, 2009 AT 8:38 PM
