1994 Mercury Sable water pump
1994 MERCURY SABLE
MLDBILL33
Engine Cooling problem
1994 Mercury Sable 6 cyl Front Wheel Drive Automatic
i need to know how to get tha stem for radiator hose off the water pump
Sep 28, 2009 at 9:59 AM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
what do you have for engine
this is for 3.8
WATER PUMP
Removal
Disconnect negative battery cable. Drain cooling system. Raise and support vehicle. Remove lower nut on both right-side engine mounts. Raise and support engine.
Remove accessory drive belts and water pump pulley. Remove power steering with hoses attached and secure aside (if equipped).
Remove A/C compressor front bracket, leaving compressor in place (if equipped). Disconnect necessary coolant hoses. Remove water pump bolts and nuts. Note bolt location. Note if sealant is applied to bolt threads. Remove water pump and gasket.
CAUTION:When bolt is removed, note if sealant is applied to threads. Some bolts are coated with sealant to prevent coolant leakage.
Installation
Install gasket using Gasket and Trim Adhesive (D7AZ-19B508-B). To complete installation, reverse removal procedure. Lightly oil threads of bolt and stud not containing thread sealant.
If bolts originally contained thread sealant, clean and reapply thread sealant to bolts. Tighten bolts and nuts to specification.
Fill cooling system.
Sep 28, 2009 at 6:50 PM
