1994 Mercury Sable power steering
EMAHONEY1977
  • 1994 MERCURY SABLE
Steering problem
1994 Mercury Sable Two Wheel Drive Automatic
Is there a way to toatally drain the power steering in a 94 sable 3.0
Sunday, April 19th, 2009 AT 1:01 PM
JGAROFALO
  • 489 POSTS
No easy or neat way that I know of. It is a messy job any way you do it. To totally drain the system would require a way to force ALL of the oil from the pump, steering rack, and lines. Not an easy task.
Monday, April 20th, 2009 AT 5:52 PM
PERRATZO
  • 7 POSTS
Really?
I am about to try the drain/replacement one-step approach.
- Get a gallon of new PS fluid from auto parts store.
- Disconnect return line to PS pump and direct it to a bucket.
- Remove the PS reservoir cap.
- Have a helper turn car on.
- As you notice old, sooty ps fluid go into the bucket, start pouring in new PS fluid.
- Continue, ask helper to turn steering end to end a few times.
- Go on until clear oil comes out of the return line.
- Turn car off and plug hose back into the PS pump.
- Check level at reservoir and top off as needed.
- Close reservoir cap.
Drive happy : )
Friday, July 9th, 2010 AT 2:02 PM
