1994 Mercury Sable dash clock problems
107,800 MILES • 6 CYL • FWD • AUTOMATIC
SCOTTISHPC
I have a problem with the clock in the dash. During
normal daytime driving the clock works fine, light come on and it keeps correct time. When you turn the lights on, daytime or night time, the clock stops keeping time and the light only comes on once in awhile. The time never changes.
I have changed the headlight switch and it has not helped solve the problem, still the same.
Any sugestions or help with this problem???
Feb 24, 2009 at 1:38 AM
JGAROFALO
  • 489 POSTS
This sounds like an internal problem with the clock itself. Since these clocks are serviced only as a unit, I suggest that you get another one from a salvage yard and replace it. The cost is usually minimal, and it is easy to replace.
Mar 7, 2009 at 1:02 PM
