i have a 1994 mercury sable 3.8 liter with a automatic trans it doesn't shift out of first what is the problem and how do i fix it?
Dec 16, 2009 at 6:03 AM
BMRFIXIT
✓Experienced Mechanic
Visually inspect all electrical wiring, looking for chafed, stretched, cut or pinched wiring.
Ensure electrical connectors fit tightly and are not corroded.
Ensure vacuum hoses are properly routed and are not pinched or cut.
Inspect air induction system for possible vacuum leaks.
Check PCM, sensors and actuators for physical damage.
Check engine coolant level.
Check transmission fluid level and condition.
chek for codes
