1993 Mercury Sable signal lights
130,000 MILES • V8 • FWD • AUTOMATIC
MJSCOTT
I'm having trouble with the signal lights. mostly they work but on some occasions they don't . they will slow down the speed of flashing or stop completely ; some times they will work either to the left only or to the right only.? ?? The ignition is loose and I have to be careful when putting the key in or it may stick in and I can't get it out or start the car. This has only happened twice over a four year period. The problem with the signal lights happens every other month or so. Also I cannot put the high beams on at all.?
Jan 13, 2010 at 3:21 AM
BMRFIXIT
  • 19,053 POSTS
Sounds as that you need to have the ignition replaced
and also would suspect multifunction switch
and need to be replaced too
Jan 16, 2010 at 11:17 PM
