1993 Mercury Sable rear wheel hub bearing removal
1993 MERCURY SABLE
BUSTEDKNUCKLES
Drive Train Axles Bearings problem
1993 Mercury Sable 6 cyl Front Wheel Drive Automatic
I have a manuel but it doesn't show how to remove the hub bearing for the rear drum brakes. can you help? Thanks
Jul 19, 2009 at 4:28 PM
JGAROFALO
  • 489 POSTS
[quote:23208ea09e="bustedknuckles"]Drive Train Axles Bearings problem
I have a manuel but it doesn't show how to remove the hub bearing for the rear drum brakes. can you help? Thanks[/quote:23208ea09e]
The rear hub bearings are only available as a hub assembly. Start by removing the tire and wheel, and the brake drum. Then remove the cap from the hub, You will see a large nut inside the cover. Remove this nut, and the hub assembly will slide off. Reverse the procedure to install the replacement part. Torque the nut to 190 to 220 ft-lbs (important!). Put the cap. drum, and tire/wheel back on, and the job is done!
Aug 1, 2009 at 2:07 AM
