1993 Mercury Sable heater coil
126,000 MILES • 6 CYL • FWD • AUTOMATIC
LASHON
How do you bypass the heater coil. I have steam coming in through the dashboard by the windshield. How easy is it to bypass and will it mess up the engine if it is bypassed instead of being replaced.
Nov 13, 2008 at 7:26 AM
RENAUDTN
  • 636 POSTS
Well, you could disconnect the inlet and outlet heater hoses that connect to the heater thru the firewall. Just plug the heater inlet and outlet, and connect the two hoses together. Of course, you won't have heat anymore. I don't think it would mess up the engine. The steam you see is probably a coolant leak. You probably need to replace the heater core.
Nov 13, 2008 at 7:55 AM
