1993 Mercury Sable Drive-thru overheating
MABARLOW
  • 1993 MERCURY SABLE
Engine Cooling problem
1993 Mercury Sable 6 cyl Two Wheel Drive Automatic
Whenever I pull up to a red light or go through a Drive-Thru, my car starts to overheat. It happens really fast whether I have been driving around all day or just got in the car. I can literally watch the guage go up as I sit with my foot on the brake and the car in Drive. As soon as I take my car off the brake and start going, it starts to come down. My mechanic had to tighten all the clamps on my hoses because I had a small leak and he even did a pressure test to be sure that there wasn't a leak inside the engine. I checked the coolant overflow tank and it is full. Does anyone know what the problem could be? Should I have the thermostat changed?
Sunday, October 26th, 2008 AT 8:28 PM
BLACKOP555
  • 10,371 POSTS
I would be checking to make sure the cooling fans are coming on, and the fan shroud aint cracked.
If thats all good I would try adding "water wetter" to the coolant that will cool it down just enough to stop the overheating.
Sunday, October 26th, 2008 AT 9:54 PM
