1993 Mercury Sable blinkers
59,000 MILES • 6 CYL • FWD • AUTOMATIC
BANZISUPAFLY
the blinkers in my car don't work and i have no idea what the problem is. i took the relay sensor in to have it check and its still good. i checked all the connections and everything is good and secure. do you guys have any ideas?
May 24, 2010 at 6:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
have you checked the fuse and bulbs for signals? do the hazard lights work?
May 24, 2010 at 8:38 AM
BANZISUPAFLY
th hazardss do not work and the bulbs and fuses are good.
May 24, 2010 at 1:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if bulbs and fuses are find but neither signal nor hazards work then its either faulty flasher unit or faulty switch.
May 24, 2010 at 1:34 PM
BANZISUPAFLY
alright thanks i'll get them tested. thanks for the help
May 25, 2010 at 11:36 AM
