1992 Mercury Sable will not start
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
FJOHNSON
replaced the starter now it will not turn over like its not firing was running fine
Oct 28, 2008 at 12:41 PM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Oct 28, 2008 at 12:47 PM
