1992 Mercury Sable Shifting
ESHANKLI
Transmission problem
1992 Mercury Sable Front Wheel Drive Automatic 180000 miles
I was driving my car to work and it was having some trouble accelortating. Then when I tried to go after stopping at a light it just reved. I turned it off and then back on and it drove for just a little bit before only reving again. I have done some research and it sounds like something just came disconnected. Any ideas what?? and if I could fix it myself? and where the problem is?
Aug 16, 2010 at 8:08 PM
KHLOW2008
  • 41,812 POSTS
Hi eshankli,
Thank you for the donation.
Symptoms indicate the transmission has malfunctioned and is not engaging.
Check the transmission fluid level and top up if necessary.
Get a scan done to retrieve for trouble codes and let me know the EXACT trouble code if any found.
Aug 17, 2010 at 2:45 AM
