1992 Mercury Sable Heater
139,000 MILES • 6 CYL • FWD • AUTOMATIC
JOYSEYJGB
The air conditioner in my car works but not the heater, what can it be?
Oct 3, 2008 at 10:34 AM
2CARPRO JACK
  • 11,533 POSTS
Is the radiator full of coolant? Check to see if the heater hoses get hot.If so you might have a blend door problem under the dash.There is adoor that moves from hot to cold when selected, do you hear a change in the fan noise when you move it? If not, you will need to get under there and see which door it is and if it works when selected hot or cold
Oct 3, 2008 at 12:07 PM
