1992 Mercury Sable CAR WONT STAR
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
THRIPPLEL
BATTERY HAS POWER BUT ON SWITCHING IGNITION THERE IS NO RESPONSE FROM THE ENGIUNE1.00
Jan 24, 2010 at 9:04 AM
MATHIASO
  • 1,209 POSTS
Hello thripplel Welcome to 2carpros.com Use a jumper wire to bypass the starter control circuit (jumper wire from Bat+ to starter) If starter does not crank, replace it If starter cranks, use jumper wire from Bat+ to solenoid terminal. If starter does not crank, the solenoid is defective. If starter cranks, use jumper wire to bypass the neutral safety switch If starter does crank, the safety switch is defective If starter cranks, bypass the ignition switch. If starter does not crank the ignition switch is defective If starter cranks, there is an open in the circuit between the Bat + and the ignition switch Here is the diagram I'm sending to your email for better view.
https://images.2carpros.com/forum/automotive_pictures/46384_0900c152802798eb_1.jpg
Jan 24, 2010 at 1:02 PM
