1990 Mercury Sable Heat stays on
KRRG
  • 1990 MERCURY SABLE
  • 6 CYL
  • FWD
  • 95,000 MILES
My car's climate control is stuck on 95 degrees and the fan won't shut off. The same hot air blows when I put the A/C on also. Even when I turn off the fan switch, it still blows hot air
Thursday, March 5th, 2009 AT 2:43 PM
JGAROFALO
  • 489 POSTS
The common problems here are the blend door motor and the control assembly. Problems of this nature require very specific diagnostic procedures to pinpoint causes. A shop manual is in order. You can usually find them on eBay for reasonable cost.
Of course, there is the "seat of the pants" method. For a start, I would try getting a used control assembly from a salvage yard. I thisk that should be your number one suspect.
Friday, March 13th, 2009 AT 4:57 PM
