1990 Mercury Sable CAR WILL NOT START
MARKOWW
Electrical problem
1990 Mercury Sable 6 cyl Front Wheel Drive Automatic
After my vehicle's engine overheated and ceased running... it hasn't been able to run since. It turns over but refuses to start.
May 21, 2008 at 5:24 PM
MASTERTECHTIM
  • 4,750 POSTS
it is possible that the head gasket is blown. i would remove spark plugs and crank engine over and see if coolant comes out of cylinder. if it does then the head gasket is blown
May 21, 2008 at 11:37 PM
BMRFIXIT
  • 19,053 POSTS
overheated !!
check if you have compression
you may have damaged head gasket and or heads
May 21, 2008 at 11:39 PM
