1989 Mercury Sable Windshield Wiper Spray Pump
167,500 MILES • 6 CYL • FWD • AUTOMATIC
TREWBEE1
All wiper control functions work fine except the wiper fluid spray. I believe that breaker #2 on the fuse panel controls the pump. Q#1...How do you test a circuit breaker to determine if it is working.
Q#2....Is the wiper fluid pump located on the bottom of the resurvoir? What other checks shall I make to determine why the fluid will not spray. FYI, the fluid resurvoir is full and I do not hear a pump running.....That is if you can actually hear that pump running??? Can you help?
Jan 13, 2008 at 2:51 AM
TREWBEE1
[quote:df154fd2d0="trewbee1"]Other Category problem
1989 Mercury Sable 6 cyl Front Wheel Drive Automatic 167500 miles
Q#2....Is the wiper fluid pump located on the bottom of the resurvoir? What other checks shall I make to determine why the fluid will not spray. FYI, the fluid resurvoir is full and I do not hear a pump running.....That is if you can actually hear that pump running??? Can you help?[/quote:df154fd2d0]
Jan 13, 2008 at 3:52 AM
