The Sable has fire to the plugs. How can I tell if it is getting gas and is in time. Is there a particular module that might have failed?
Jan 6, 2010 at 9:36 AM
✓Experienced Mechanic
Do you hear the fuel pump come on when you turn key to run, if so check the fuel pressure with a fuel pressure gauge to verify if its within specs-if okay -check for injector/s pulses-
If you don't hear the fuel pump-check fuel pump fuse,fuel pump relay and inertia fuel cut off switch.
