Alternator
MERCURY
LSD423
Hi and thanks for responding. I recently had a battery die on me and i replaced it. My friend told me to start the car and unplug the positive to see if it was the alternator that was bad. When i did it the car stopped running. Is a bad alternator the only reason this could happen??
Also, i recently had a new compressor installed, could this new problem possibly been caused by the mechanic that installed my compressor?? Thank you for your time.
Oct 4, 2006 at 8:55 AM
MERCCRUISER
  • 16 POSTS
I dont think so.. i would buy a new alternator and possibly a new voltage regulator
Oct 4, 2006 at 9:20 PM
LSD423
Can i repair that without taking it to the shop? If so, how do i go about doing it??? Thank you for your time. My car is a 1996 mercury Sable.
Oct 5, 2006 at 12:52 PM
MERCCRUISER
  • 16 POSTS
well.. yes and no.. umm if you dont know what your doing you could (over tighten) the belt to the alternator and i have no idea if the alternator has an internal or external voltage regulator.. if i have to guess since ford/mercury is still using stone age electronics i would guess it would be external and that you could replace very easily if you could find it.
Oct 13, 2006 at 1:29 PM
