2001 Other Mercury Models Spark Plugs
2001 MERCURY
74,000 MILES • V8 • 2WD • AUTOMATIC
JOEL C. COLLINS
My code scanner says misfire on #4.I intend 1st to install new spark plugs.1-Which is #4?. 2. What is prcedure for installing new,i.e is it necessary to remove fuel pipes feeding injectors?
Mar 19, 2008 at 1:26 AM
2CARPRO JACK
  • 11,533 POSTS
What kind Of Mercury? What engine? No it isnt necessary to remove the fuel rail,pull the coils out and replace plugs one at a time so the coil goes back in the same cylinder. The cylinder on the drivers side in the front as you are staniding in fron of the truck looking at the engine
Mar 19, 2008 at 4:48 AM
BMRFIXIT
  • 19,053 POSTS
this is what i have on ford V8 engine cylinder line up hope that will help
https://images.2carpros.com/forum/automotive_pictures/99387_ford_v8_1.jpg
Mar 19, 2008 at 5:33 AM
2CARPRO JACK
  • 11,533 POSTS
Thx for the catch. my bad. last one on pass side
Mar 19, 2008 at 6:59 AM
