1998 Other Mercury Models Where is the Oxygen sensor Located
1998 MERCURY
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
JTH
Where is the Oxygen Sensor located on my 1998 Mercury sable LS station Wagon. I need to replace it
Feb 2, 2009 at 5:18 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:8093f33f61="JTH"]Electrical problem
1998 Other Mercury Models 6 cyl Two Wheel Drive Automatic 110,00 miles
Where is the Oxygen Sensor located on my 1998 Mercury sable LS station Wagon. I need to replace it[/quote:8093f33f61]
The O2 sensors are located in the exhaust. Since you have a v6 you have at least 2. located in the exhaust manifold and there should be one just before the catalytic converter. If you are getting a code post the code and can tell you which one needs to be replaced.
Feb 2, 2009 at 5:22 PM
