1996 Other Mercury Models
1996 MERCURY
ALBERTO-REVMASTER
Engine Mechanical problem
1996 Other Mercury Models V8
this boat engine,its been repair twice,and on both repair spun rod's 1st time and main 2nd time,both repair the crank has been replace,boat ran fine for about 17 hrs,for us we think engine its been run lean.hope we can find an answer thanks:
Aug 6, 2008 at 12:47 AM
  • 31,937 POSTS
Hi there,
I would be checking the oil galleries for a blockage checking hot oil pressure as well as the failure of the bearings will be due to lack of lubrication rather than a lean mixture, What fuel are you using if a blended racing mixture then i would also be checking the fuel system as this will cause over heating issues and in extremes may affect bearings if the oil system is not running a cooler and the oil temp is running to high.
mark (mhpautos)
Aug 6, 2008 at 12:55 AM
