All I can think of is the fan switch is bad, The high blower is a seperate cicuit than the normal fan speeds
Mar 3, 2007 at 11:35 PM
WALTC
MEMBER
1 POST
Every thing seems to work very well except tac is offhe fan runs all the time on high even when the heat/AC s off
3.8 V-6,1993,106.000
Jan 26, 2007 at 11:27 PM
MERLIN2021
✓Experienced Mechanic
BHUGG
Check under the hood for a power distribution box. It has fuses and relays. There is a blower relay there. swap the relay with another like kind relay and see if that solves your problem.
I have had some problems with these relays too.
Good luck.
Let the forum know what happens. We like feedback.
