1989 Other Mercury Models takes too long cranking to fire in
1989 MERCURY
110 MILES • V8 • 2WD • AUTOMATIC
ELIE AYOUB
fuel pressure is good ignition syst is firing normal . some time i spray starting fluid in intake manifold to get it going . is the problem in the coolant sensor or the oxygen sensors . if the coolant sensor is the problem where it is located ? engie is v8 5.0L car MER.grand marquis . appreciate your help. thks E.A
Nov 8, 2009 at 1:46 PM
Could be the coolant temperature sensor its located on top of the engine to the right of the distributor
Nov 9, 2009 at 2:30 AM
