1982 Other Mercury Models Cannot get shift lever out of park
1982 MERCURY
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
JRMAC4
1982 Mercury Zephyr. The floor mounted (original equipment) shifter will not come out of park when the side button on shifter is pressed in. Is there a simple way to check a linkage or spring control that controls the shift lever to see if it broken or bent or is it just rusted?
Apr 13, 2009 at 2:37 PM
HMAC300
  • 48,601 POSTS
if you can pull the console up and look at where the button releases the abt switch then you'll be ok but that is abou tthe only way to do it.
Jan 26, 2010 at 9:25 AM
