dpfe is faulty
MERCURY MYSTIQUE
KEV1962
I have white smoke coming out of my tail pipe. What could be the cause. If the dpfe is faulty could this be the probllem? I do not have water in the oil.
The car is a 1997 Mecury Mystique 120000 miles the engine size is 2.0
Mar 25, 2007 at 4:46 PM
MERLIN2021
  • 17,250 POSTS
There is a recall on 95-97 Mystiques for wiring harness degradtion. P0401 codes if present indicates your car may be covered under the recall.
Insufficient flow. As for the white smoke...usually this is anti-freeze being burned off. Do a compression test. U may need a head gasket!
Mar 26, 2007 at 12:30 AM
