HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mercury
Mystique
Engine
Symptoms
Not Running
2000 Mercury Mystique
GAMA
MEMBER
2000 MERCURY MYSTIQUE
4 CYL
2WD
AUTOMATIC
126,000 MILES
The car cranks but will not start what do I check to find the problem?
Sunday, March 16th, 2008 AT 5:30 PM
BLACKOP555
MECHANIC
First you should buy a spark tester and check each cylinder for bright blue spark and post back what you find.
Sunday, March 16th, 2008 AT 8:40 PM
RODMAN1
MEMBER
How long has it been since you replaced the timing belt?
Friday, April 11th, 2008 AT 11:08 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Turns Over But Will Not Start When It Is Cold...
I Seem To Have This Problem Only On Colder Nights. Why Is That? I Have Had Trouble Recently With Car Not Starting On Cooler Days. It Will...
Asked by
momma_shelton74
2000
MERCURY MYSTIQUE
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Mercury Mystique Car Will Not Start
Ok, Here Is My Whole Story And Hopefully Someone Can Help. I Bought This Car With 180000 Miles Already On It And It Seemed To Run Pretty...
Asked by
aperez82
1997
MERCURY MYSTIQUE
Car Will Not Start
Its My Neices Car. 98 Mercury Mystique. She Started It On Friday Morning, And It Stalled. Started It Later In The Day And The Engine Was...
Asked by
mrmike
MERCURY MYSTIQUE
1996 Mercury Mystique Car Will Not Start.
After The Car Goy Hot And Shut Down It Will Not Start. It Will Turn Over But Will Not Start. If I Disconnect The Battery And Reconnect It...
Asked by
blondemex
1 ANSWER
1996
MERCURY MYSTIQUE
1999 Mercury Mystique Car Won't Start When It's Cold
Engine Problem 1999 Mercury Mystique Two Wheel Drive Automatic 140000 Miles The Car Won't Start When It's Cold. The Starter Cranks...
Asked by
Sideslip1960
1999
MERCURY MYSTIQUE
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
