1999 Mercury Mystique i have a two part question
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
COLIH
the chck eng. light on when have the code run it comes back as #4 CYLENDER MISFIRE i changed the spark plugs and wire and coil. it has a spark and there is fuel getting to the cylender there was the smel lof fuel on the spark plug
my turn siginal dont work at all and haz. light i changed the flasher and multitask switch
Apr 8, 2008 at 5:07 AM
RODMAN1
  • 7 POSTS
Did you check the injectors, sounds like an injector problem to me.
Electrical problem, this model has some funky electricals. Check the obvious first then check for groundings. like engine to body and battery to block then every other ground point. You'll need a schamatic of the electricals to do this.
Apr 8, 2008 at 12:19 PM
