1999 Mercury Mystique engine problems
151,000 MILES • 4 CYL • FWD • AUTOMATIC
GMCALWAYS
When i cut the car on and also when it sits still at a stop sign the engine jumps and threatens to cutoff. and every morning when i cut the car on it jumps then cuts off. also makes a rough sound when wheel is fully turned.
Feb 28, 2010 at 2:12 AM
SILENTONE
im having the same problem..... it seems like the idle low every time i get to a light/stop it drops blow the 1rpm an dies or jumps a bit
Jan 1, 2011 at 6:29 PM
