1998 Mercury Mystique wont idle cold
1998 MERCURY MYSTIQUE
72,000 MILES • 6 CYL • FWD • AUTOMATIC
CRAZYBULL2455
check engine lights on
wont idle can it be o2 sensor if so which one
it has 2 on it
one before catatlicy convert
or one after
Jul 14, 2008 at 8:59 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away!
Jul 14, 2008 at 9:11 AM
