1998 Mercury Mystique egr valve
1998 MERCURY MYSTIQUE
INITIAL
Engine problem
1998 Mercury Mystique 6 cyl Wheel Drive Type unknown Automatic 85,000 miles
according to the check engine light code, the egr valve needs replaced. How is it done?
Jan 13, 2008 at 3:31 AM
MERLIN2021
  • 17,250 POSTS
Is it P0401? Valve may not need to be replaced...Pull the egr off, clean the port under it all the way to the throttle plate, I use a length of steel coathanger...put it all back together, reset the codes, if light comes on again, replace the EGR position sensor, thats the one the two small hoses from the exhaust plug into!
Jan 13, 2008 at 3:34 AM
