1998 Mercury Mystique Crankshaft Sensor
1998 MERCURY MYSTIQUE
ICOPYIT
  • 5 POSTS
Engine Performance problem
1998 Mercury Mystique 4 cyl Front Wheel Drive Automatic 90K miles
Thanks for any help you can give at this point. My daughter took her car in for a craftshaft position sensor code. They replaced the sensor, the code did not clear. They told her it needed a new on board computer. That didn't work either. Their final analysis was that she should junk the car and the real problem may be a plate related to the timing belt. She just sank a rebuilt tranny, new brakes, rotors, brake lines (front to back) and new tires into this car. What could be the problem?
Jan 12, 2009 at 6:43 AM
JAMES W.
  • 2,394 POSTS
With only 90K on the car, let's not panic just yet. Did they clear the CPS code and it cane back again? Also, was there a driveability problem with the car before all this started? Please advise.
Jan 12, 2009 at 7:33 AM
ICOPYIT
  • 5 POSTS
Problem started just after the brakes were repaired. At first it was only intermittently and only after the car warmed up. After the sensor was changed, the problem got alot worse. They could not clear the code (reason for changing the computer).She was able to drive the car about a mile from the dealership. Upon stopping at lights etc., the car would chug and sometimes stall. She drove it to an autoparts store and had them check the code : P0340 (same code after changing the sensor). She could not get it to run without giving it alot of gas and had it towed back to the dealership that changed the sensor, at which time they claimed the computer was the problem and replaced it.
Jan 13, 2009 at 8:47 AM
JAMES W.
  • 2,394 POSTS
Has changing the ECM solved your problem? Please advise.
Jan 14, 2009 at 1:20 PM
ICOPYIT
  • 5 POSTS
No. We are still getting the same symptoms (chugging, stalling, P0340 code).
Jan 15, 2009 at 11:48 PM
JAMES W.
  • 2,394 POSTS
Out of curiosity, what did the dealer say after changing the ECM didn't solve your problem? Did they check fuel pressure and the EGR valve?
Jan 17, 2009 at 8:45 AM
ICOPYIT
  • 5 POSTS
He said he didn't know what was wrong with it and to not spend anymore money on the car. To our knowledge, the fuel pressure and EGR valve were not checked. The car STILL has P0340 showing as the code. Is it possible another sensor is faulting and a false code is presenting?
Jan 18, 2009 at 2:46 AM
JAMES W.
  • 2,394 POSTS
It's not impossible the new sensor is bad. I just had a GM product with the same symptoms. He had a brand new CPS right out of the box from GM that was bad. One thing I have learned over the years is, believe the computer. Too many ECMs are changed out needlessly, because people didn't believe what they were telling them.
Jan 18, 2009 at 11:06 AM
ICOPYIT
  • 5 POSTS
I doubt that faulty or bad new sensor was a possibility to the mechanics that are working on the car right now, otherwise they would have checked that before installing a new computer. Your advice is certainly something worth checking. I will pass this along to my daughter. I really appreciate you taking the time to help me with this problem. You've been very helpful! If we are able to find the exact source of this problem, I will certainly send it along to you and your readers!
Have a nice day!
Jan 19, 2009 at 11:29 PM
MALEVIAN
The problem could be that a p0340 code is actually the camshaft position sensor and not the crankshaft sensor. Are you sure the right part was replaced?
Apr 17, 2009 at 9:15 AM
