1997 Mercury Mystique
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANTONIO NEGRETE
why when i conect the coolant sensor , the fan turn off?
Apr 21, 2009 at 2:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The coolant sensor lets the fan know when to come on. If engine is not warm enough to need the fan on then the sensor will not allow fan to run. If engine is starting to overheat but fan still will not come on then it is because your sensor is faulty.
Thanks for using 2CarPros.com!
Apr 21, 2009 at 2:55 PM
