1996 Mercury Mystique power widows
1996 MERCURY MYSTIQUE
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
FISHINGENIUS
No window control from drivers door. Passenger front opens and closes normally from the passenger side. Neither rear window will operate from anywhere, I assume because they are locked out from the drivers door switch. Drivers window switch is new but there is no voltage to it ( the switch is lighted and that part works). Fuse is good and there is voltage at the fuse. is there a relay somewhere? I don't see any under the dash other than the ones in the fuse block. The book lists a window express relay but does not tell where it is, there is a relay in the drivers door and that may be it, but no voltage there either. I assume the power goes thru the switch and then to the relay. All wiring and connectors look good.
Sep 11, 2010 at 9:20 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Hi fishingenius. Welcome to the forum. Sounds typical of a broken wire between the door hinges.
caradiodoc
Sep 12, 2010 at 1:16 AM
