1996 Mercury Mystique Please help! Belt problem?
1996 MERCURY MYSTIQUE
134,000 MILES • 4 CYL • FWD • AUTOMATIC
MICHELLE27
Please Help If You Can!!
I have a 1996 mercury mystique.
I relpaced the altenator and after a week now there is a knocking noise coming from that area. The mobile mechanic came out again and said it needs a timing belt now, although the timing belt looks new, and some gaskets and while he's in there I should replace the water pump and gasket also.
I called the previous owner, as I just bought the car a week ago, to see if he had any paperwork for the car in regards too belts.He had told me about the need for an altenator. He said maybe the mechanic did something to the serpentine belt when he replaced the altenator. I don't know what I should do now? Mechanic said not okay to drive, but I'd like to get a second opinion. Is the serpentine belt idea a possibility?
Apr 19, 2009 at 1:24 PM
BMRFIXIT
  • 19,053 POSTS
If the timing belt looks new why it need to be replaced
should have another tech take a look at it for you and evaluate the situation for you
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 19, 2009 at 1:30 PM
