1996 Mercury Mystique my brake lights do not work
LISADIANE3742
Brakes problem
1996 Mercury Mystique 6 cyl Two Wheel Drive Automatic 104.00 miles
I replaced fuses.bulbs took to a shop and just dont know what to do? can you help lisa
Mar 2, 2010 at 8:52 AM
  • 75,988 POSTS
If the brake switch is adjusted properly or good and passsing power-I suggest you have the hazard switch tested the lower brake circuit goes thru there.
Mar 2, 2010 at 9:13 AM
