1996 Mercury Mystique ENGINE IDLE
18,000 MILES • 4 CYL • FWD • AUTOMATIC
MARK W
1996 Mercury Mystique 2.0L mileage: 180,000.
Just had the cly. head / valves / headgasket done.
car running great for a few days, now while driving the car, the idle speed went up to 2,000 - 2,500
RPM and will not go lower. I unhooked the throttle and cruise control cables, no change. Throttle body butterfly valve looks fully closed.
I unplugged the mass air flow, the idle did drop but
idled very rough and stalls.
Aug 24, 2010 at 4:09 AM
WRENCHTECH
  • 20,760 POSTS
The engine likely has an air leak somewhere letting unmetered air into the system.
You could have a bad IAC (idle air control) but would more suspect there is a line off.
Aug 24, 2010 at 4:48 AM
