1996 Mercury Mystique cant find the starter
1996 MERCURY MYSTIQUE
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEASYFENCE
haynes manual says to romove filter, and massflow sensor (done) then remove the top two bolts from the starter. I don't even see the starter. Help!!
Apr 4, 2009 at 12:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Anytime you have difficulty finding the starter just follow the positive battery cable down under engine. It leads straight to the starter ;) Starter is on bottom rear of engine.
Thanks for using 2CarPros.com!
Apr 4, 2009 at 5:32 PM
