1995 Mercury Mystique engine cooling fan
1995 MERCURY MYSTIQUE
16,000 MILES • 4 CYL • FWD • MANUAL
FRTBMB
Fan does not work. I replaced the sensor and thermostat. The fuse is o.k. but I have no power to the motor even after the engine is warmed up. The temp gauge does not work. Why doesn't the fan work?
Aug 24, 2009 at 11:01 PM
RACEFAN966
  • 5,029 POSTS
I need some info first so I can help. Do you have A/C? How many fans do you have 1 or 2? Have you checked any of the relays to see if you have power to them? Do you have a digital multi meter? Get back to me and we will go from there.
Sep 1, 2009 at 3:18 AM
