1995 Mercury Mystique 1995 Mercury Mystique Transmission re
327,000 MILES • 4 CYL • FWD • AUTOMATIC
DONNY123
Hello,Yes the mileage is very correct! The Ford dealership took the car for a test drive and the car started to buck and jump into gear and also rpm's almost when through the roof while driving.They put it in low 1, it wanted to jump into 2,put it in 2 wanted to jump into D. They said I need a new transmission,they where too busy for the job,recomended another mechanic.Took it to him he did a code read on it and said it wasn't the transmission but the fuel pump(fuel pump failure code)Before I took it to the mechanics I had drained the old,black thick,burn't smelling oil ,flushed it with new oil,new filter.
What type of trans rebuild kit do you recommend?
Would a fuel pump cause these types of systems?
Mar 31, 2008 at 11:40 PM
RODMAN1
  • 7 POSTS
No but the torque converter will. But it sounds like the tranny is loose. Did you check the tranny blots?
Apr 8, 2008 at 12:24 PM
