2005 Mercury Mountaineer hesitation at cruising speeds
58,955 MILES • 6 CYL • AWD • AUTOMATIC
ZIPPY216
I have a 2005 Mountaineer with awd and v6 4.0l engine. In the past 6 months it has begun to hesitate while at cruising speeds. when diving on the highway, the engine or transmission will start to hesitate or miss between 1000 and 2300 (approx.) rpms. I had it into the dealer and they gave me a laundry list of things that needed done, most of which were listed in the manual at 60,000 miles. They did say that the computer showed misfires in the lower rpm range. They suggested I replace the spark plugs and wires. Which I had changed as well as change the fuel filter. Problem is nothing has changed. I personally think it has to do with the transmission. If it was doing this hesitation while driving in the rpm range, wouldn't it do the same thing while in PARK and just reving the engine if it was the spark plug suggestion.
I would appreciate any help that you may be able to offer to remdy this problem.
Thanks
Dec 30, 2009 at 2:35 AM
LEOCLAY
My Mountaineer has done the same thing for the last year I have owned it... It seems to do it somewhere near when it shifts gears (automatically)... It is very random, though.
Jan 22, 2010 at 7:19 AM
ZIPPY216
Have you had it looked at yet? Any idea what is causing it? I am at my wits end. I have already had it in the shop 3 times and had multiple parts replaced with no change. I am thinking about trading it in for a newer model.
Jan 24, 2010 at 10:35 PM
