Engine stalls on the Road
65,000 MILES • V8 • AWD • AUTOMATIC
70 PLUS
  • 7 POSTS
I am driving along on the highway and the motor dies. I coast to the side of the road, put it in neutral and it starts back up with no problem and I drive off. It won't happen again for a while.
Jan 25, 2010 at 12:29 AM
RACEFAN966
  • 5,029 POSTS
Tell me is the check engine light on? How does it stall does it just die or does it loose power and then eventually die? It sounds like a crankshaft angle sensor.
Please run this guide.
Cheers
Jan 26, 2010 at 2:06 AM
70 PLUS
  • 7 POSTS
The check engine light is not on. It is not gradual. It is like I turned the key off.
Jan 26, 2010 at 8:07 AM
RACEFAN966
  • 5,029 POSTS
Ok so do you have a digital multi meter? I would like to check the camshaft sensor. Thanks
Jan 27, 2010 at 3:05 AM
70 PLUS
  • 7 POSTS
I took it to my mechanic and he said he connected it to his computer and nothing came up. Is that what you mean?
Jan 27, 2010 at 6:31 AM
RACEFAN966
  • 5,029 POSTS
Ok that just means there are no codes we already knew that because the check engine light isn't on. Now what I would like to do is check the camshaft sensor.
Jan 28, 2010 at 2:14 AM
70 PLUS
  • 7 POSTS
I have a CarMD Handheld Tester. I don't think that's what you're asking for so the answer is no.
Jan 29, 2010 at 12:24 AM
RACEFAN966
  • 5,029 POSTS
Ok we either need to get our hands on a digital multi meter or have the cam sensor checked. It could have corrosion on the plug or not be sending the signal correctly or? Here is a pic of a inexpensive multi meter. If you are not comfortable doing these tests please just let me know and I will let you know what tests I would run if you would rather have a shop do it ok.
https://images.2carpros.com/forum/automotive_pictures/249564_14572_1.jpg
Jan 29, 2010 at 2:40 AM
70 PLUS
  • 7 POSTS
I don't know enough about mechanics to do the tests so please tell me what to tell my mechanic.
Jan 30, 2010 at 6:52 AM
RACEFAN966
  • 5,029 POSTS
Ok if you would have him unplug the camshaft sensor and ohm it. Get back to me with what you find and I will look it up to see if it is in spec.
Feb 1, 2010 at 4:30 AM
70 PLUS
  • 7 POSTS
Thanks. I will do that and get back to you.
I have to do some traveling so it may not be for a while.
Feb 1, 2010 at 11:24 PM
RACEFAN966
  • 5,029 POSTS
No worries when ever you get to it just let me know what the readings are when you get them.
Feb 2, 2010 at 12:48 AM
70 PLUS
  • 7 POSTS
I talked to my mechanic about ohm-ing the cam sensor and he didn't understand. So we replaced the sensor and that fixed the problem your hunch was right thank you so much for your help I love this site.
Feb 6, 2010 at 1:39 AM
RACEFAN966
  • 5,029 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Feb 8, 2010 at 10:42 AM
