2004 Mercury Mountaineer
DMORRISON25
Transmission problem
2004 Mercury Mountaineer 6 cyl Two Wheel Drive Automatic
The wrench light came on the dash and the transmission started to shift quick and hard.
Jan 17, 2010 at 4:26 PM
BMRFIXIT
  • 19,053 POSTS
Its been a while since oil was changed
check fluids and if all OK you can reset the maintenance light
Press and release SETUP button until the message center displays PRESS RESET AT OIL CHANGE.
Press and release the REST button until the message center displays HOLD RESET TO CONFIRM.
Press and hold RESET button for 2 seconds and release to reset the oil life to 100%.
Press the SETUP to exit the procedure and continue with the system check.
Jan 17, 2010 at 10:27 PM
