2003 Mercury Mountaineer smog test failed
2003 MERCURY MOUNTAINEER
100,000 MILES • V8 • 2WD • AUTOMATIC
I took my 2003 mercury mountaineer in for a smog check and all was good except my "service engine soon" light is on. The OBD code is po401 (EGR flow is insuficient). I don't know much about the EGR system but I did a visual inspection and did'nt see anything diconected ,etc. Can anyone tell me some likely causes or things to check?
Mar 31, 2009 at 11:26 AM
  • 110,244 POSTS
Remove the EGR. Chances are it has carbon build up and the valve is sticking.
Let me know what you find.
May 11, 2009 at 2:56 AM
