2003 Mercury Mountaineer O/D light blinking and then Servic
99,000 MILES • 6 CYL • AWD • AUTOMATIC
RICKBURKETT
While traveling up a sharp incline at work this week, my O/D light started blinking. The vehicle would not move either. I put it in park and tried again and the light stayed on blinking and the vehicle would still not move. I put it in park and shut the engine off re-started it and the O/D quit blinking. I could then proceed up the hill at that time.
This happened two days later...same thing my O/D light started blinking. The vehicle would not move either and then Service Engine light came on. I put it in park and shut the engine off re-started it and the O/D quit blinking but the Service Engine light stayed on. I could then proceed up the hill at that time.
I had the code read and there was only one. It said "speed sensor"
I just had the transmission replace about 7,000 miles ago. The vehicle was jumpung in and out of O/D before that and the mechanic said I needed a new transmission. It still does not drive right. It slams into gear quite often when shifting from neutral to reverse and it still seems to jump in and out of OD occasionally.
Jan 23, 2009 at 1:54 AM
  • 110,246 POSTS
The speed sensor can cause the problem, but if you only have 7K on the new trans, I would think it is under warranty.
Jan 30, 2009 at 2:41 AM
RICKBURKETT
[quote:ed7f685e92="Jacobandnickolas"]The speed sensor can cause the problem, but if you only have 7K on the new trans, I would think it is under warranty.[/quote:ed7f685e92]
Is the speed sensor on this vehicle normally part of the transmission replacement and therefore it should be covered under warranty?
Jan 30, 2009 at 6:55 AM
  • 110,246 POSTS
Hi: The speed sensor isn't part of the trans. Here is a schematic of how it's wired into the system. If this isn't the problem, I would be in touch with the rebuild company.
https://images.2carpros.com/forum/automotive_pictures/249084_speed_sensor_1.jpg
I hope this helps. Joe
Jan 30, 2009 at 8:38 AM
RICKBURKETT
Thanks Joe, Can you tell me where the VSS is physically located on this vehicle....I am an electrician...should this be simple enough that I could change it? Rick
Jan 30, 2009 at 11:37 AM
  • 110,246 POSTS
Ok, I was able to locate 3 different ones. Although it's not part of the trans, there is a VSS out put on the top of the trans. Here is a picture of one and its location.
https://images.2carpros.com/forum/automotive_pictures/249084_trans_1.jpg
There are two more on the transfer case for the auto 4wd, but I don't think this is the problem. Here are their locations and pictures. Both are on the transfer case.
https://images.2carpros.com/forum/automotive_pictures/249084_sped_sen_1.jpg
https://images.2carpros.com/forum/automotive_pictures/249084_speed_1.jpg
Let me know if this helps. The one on the trans will be hard to access. That is the only problem I see, and I think that is the one you want. Let me know if this helps. Joe
Jan 30, 2009 at 12:59 PM
RICKBURKETT
Thanks again Joe You refered to a VSS on the top of the transmission but none of the three in the top drawing are specifically called a VSS. One is the turbine shaft speed sensor, one is the intermediate shaft speed sensor and one is the output shaft speed sensor. Is the VSS you refered to one of these?
Jan 31, 2009 at 12:03 AM
  • 110,246 POSTS
I spoke with another mechanic and he said it's the one on the rear of the transfer case.
Let me know how it works out for you.
Jan 31, 2009 at 11:51 AM
