2002 Mercury Mountaineer popping while turning
18,100 MILES • 6 CYL • AWD • AUTOMATIC
WILLUSMITH
I'm experiencing suspension thumping and popping sounds whenever I make sharp turns in my Mountaineer, as well as whenever the vehicle is parked on inclined terrain. This makes parallel parking virtually impossible and diminishes the car's ability to make u-turns. The front driver side tire is becoming worn due to this problem. I suspect the possibility of a ball joint or tie-joint failure. I contacted the local dealership for help and they agreed but when I spoke with another mechanic, they suggested cv joint.. Help
Jun 19, 2008 at 7:00 AM
DOCFIXIT
  • 18,828 POSTS
Could be ball joint that of the things listed is only one that can cause tie wear.
Whhere is wear occuring?
Jun 19, 2008 at 7:24 AM
WILLUSMITH
[quote:4bc2ddb7ee="Docfixit"]Could be ball joint that of the things listed is only one that can cause tie wear.
Whhere is wear occuring?[/quote:4bc2ddb7ee]
Jun 19, 2008 at 7:28 AM
