2002 Mercury Mountaineer NEED HELP
TORNEDO
Computer problem
2002 Mercury Mountaineer 6 cylinder Two Wheel Drive Automatic
the airbag light on the instrument panel flashes then stays on. whats wrong and is there something i can do to fix it? garage wants $75.00 just to hook up to computer.. please help!!!
Apr 19, 2008 at 1:38 PM
BMRFIXIT
  • 19,053 POSTS
does the horn work
if u answer no
you need a clock spring
Apr 19, 2008 at 3:29 PM
TORNEDO
[quote:dc3ca8abc5="BMRFIXIT"]does the horn work
if u answer no
you need a clock spring[/quote:dc3ca8abc5]horn works fine what is a clock spring?
Apr 20, 2008 at 7:05 AM
BMRFIXIT
  • 19,053 POSTS
its the connector sits under driver air bag
90% of air bag light on was solved by replacing it
its about $80
to be 100%
u need to check it for codes then
Apr 20, 2008 at 1:03 PM
