2002 Mercury Mountaineer creeking noises
130,000 MILES • 6 CYL • AWD • AUTOMATIC
MARIE LOURIA
Hi....my mountaineer has started making noises that I "think" are coming from the rear....it sounds like I am riding in a stagecoach !! The best description of the noise is a "creek" It is loud. You can also move the car while outside and it will creek. Any ideas? Thanks
Jun 23, 2009 at 4:27 AM
  • 110,248 POSTS
Check the shocks mounts and the rear sway bar bushings to make sure they are not dried out and cracking. You could try spraying them with something like WD40 to see if there is a change.
LEt me know if it helps.
Jun 29, 2009 at 9:03 AM
