2002 Mercury Mountaineer brake lights won't come on
84,500 MILES • V8 • 4WD • AUTOMATIC
ASAVAGE
Please advise why brake lights won't come on
Jan 22, 2009 at 10:41 AM
BMRFIXIT
  • 19,053 POSTS
Check fuses
check brake light switch
if you have the 3rd light coming on
suspect and check multifunction switch
Jan 22, 2009 at 10:53 AM
KEVIN12881
  • 336 POSTS
may be your brake switch. you can test it with tester, but i do not know your make and model. donate a few bucks for a pro to help, they may help anyway. also check your fuses and make sure both bulbs are good. you should be able to locate the sitch on the brake pedal , push it in and check for hot wires.
